I got a po342 and po343 code on my small cheap code reader. I have a check engine light; I installed a new cam sensor and cleared the codes. truck started right up. I let it run for about 20 minutes, shut it off, restarted it and the light came back on. A friend of mine said to replace the crank sensor too. I went through the same procedure and got a light on the dash. I guess my question is, does this truck call for sensors that need to be programed and if so, how. I don't have access to fancy meters or scanners. What can I do? Please help me!
Aug 16, 2023 at 6:17 PM
