2005 Cadillac STS
MS_IMAJIN
  • 2005 CADILLAC STS
2005 Cadillac STS 6 cyl Automatic 31000 miles
Hi, my Engine light comes on & goes off randomly. Any reason why? I have the diagnostic code, its P0036
Monday, February 22nd, 2010 AT 1:53 PM
FACTORYJACK
  • 4,159 POSTS
The code DTC P0036 HO2S Heater Control Circuit Bank 1 Sensor 2, relates to the post cat oxygen sensor on the rh(passenger) side. The quickest way to check if it is a bad sensor is to check the resistance of the sensor heating element. On the sensor, it would be the wires that correspond to pink/black, and black/white from the harness side, pins C and D. It should have relatively high ohms, but not open circuit. Or change the right with the left and see if the code changes to p0056.
Tuesday, February 23rd, 2010 AT 11:53 PM
MS_IMAJIN
I just went and had the o2 sensor replaced, no engine light since! Im happy now!
Wednesday, February 24th, 2010 AT 8:28 AM
