The ABS, brake and torsion warning lights stays on and as a result my seat heater, rear defogger, temp
control will not work. After awhile, the lights will turn offf and everything will work fine. My brakes were changed about 5000 miles ago and since then this problem has acted up. Can you help me. Thanks
I had the brakes checked and everything is O.K. However the mechanic says that there must be a module not communicating with each other to turn off the warning lights. Now when the A/C is supposed to turn on I get nothing but more heat coming out of the vents. Any help?
Dec 18, 2008 at 6:55 PM
