Transmission problem
2000 Cadillac SLS V8 Front Wheel Drive Automatic 164K miles
Vehicle is setting service engine soon light for codes: P0741 & P1860
741= TCC stuck off
1860=PWM solenoid electrical fault
Both codes seem like they could be the result of the same failure however, I would like to know if I can reasonably troubleshoot this gripe with the tranny still in the car? Prob cause could simply be a short or open circuit which I should be able to confirm before obligating to a full on transmission overhaul.
In your experience, are these codes a sign of the devil?
I'm praying that is not the case; quote for repair over $4,000
741= TCC stuck off
Aug 31, 2010 at 10:30 AM
