Car seems to over heat real fast for no reason, I know one fans kicks on but still cant figure out what the problem can be.
Wednesday, March 10th, 2010 AT 12:16 AM
FACTORYJACK
MECHANIC
Is the temperature of the upper hose hot, when it indicates overheat, if not you could have a thermostat stuck closed. At any rate, as I tell everyone with Northstar overheat issues, have the cooling system tested for the presence of combustion gases. There is a probability of an internal leak causing overheat.
