The EGR valve mounts to the rear of the water pump housing, and is held on w/2bolts/studs. My question is: is the egr valve mounting base threaded or does it drop on the studs? How can I remove it? How do I open or clean the egr valve after I take it off?
Mar 9, 2010 at 6:22 AM
