1996 Cadillac Seville HVAC Blower won't turn off on 96 Sevi
1996 CADILLAC SEVILLE
115,000 MILES • V8 • 2WD • AUTOMATIC
SEAAMIGO
The battery was going dead overnight. I discovered that the blower was moving at a very low speed, even when the car was turned off. I unplugged the blower and the drain stopped. The a/c display inside the car seems to be going through all the motions. It opens and closes the proper doors, etc. However, it won't modulate the blower speed, even though it says it is, and won't turn it off, even through it's reading "off." I removed the old blower and direct-wired it and was still getting a speed so low that I could stop it with my hand, so I figure the blower was bad. I put a new motor in, and this one is stuck on high, no matter where I set the display, and it also won't turn off when the car is off. I figure that the motor control is stuck on high, and the difference between the speed of the old and new motors was due to the old motor being woirn out anyway. Is there a relay for the blower motor, and if so, where is it? is there something called a Body Control Module that might be affecting this? If so, where is it? I know that there is a switch on the older Sevilles on the firewall next to the blower, but I think they changed that in 95 or 96, and there is nothing like that there. Thanks for any suggestions.
Feb 17, 2010 at 1:36 PM
FACTORYJACK
  • 4,159 POSTS
The instrument panel cluster, or climate panel(w/analog cluster) sends speed requests on the data line to the Heater/A/C programmer. The programmer sends a speed output to the blower on the gray wire. Judging from the schematic it looks like a digital signal. The programmer is under the rh side of the dash, near the PCM. I doubt that the data line is sending a speed signal when shut down. I would disconnect the programmer connector C2, it is a 32 way blue connector. Do this when it is powered down.
Feb 17, 2010 at 2:22 PM
SEAAMIGO
I'll try that, but I'm not sure I understand why disconnecting the plug is going to fix the problem. Are you saying this will reboot it? Or are you advising me to just leave it disconnected?
Feb 17, 2010 at 2:53 PM
FACTORYJACK
  • 4,159 POSTS
No, I'm sorry. Disconnect it when powered down, just to verify that is where your blower is getting its power. The blower should turn off.
Feb 17, 2010 at 3:31 PM
