1992 Cadillac Seville dash lights
1992 CADILLAC SEVILLE
130,000 MILES • V8 • FWD • AUTOMATIC
KEMPFDESIGN
When I turn on my headlights my dash lights flicker and so do the lights that shine on the door handles and shift panel light. my radio works fine and so do the headlights. After about 20 minutes they slowly slow down on flickiering and start phasing in and out then they stop and start working fine. I checked all the fuses. and dont know waht to do know
Apr 6, 2009 at 6:04 PM
FACTORYJACK
  • 4,159 POSTS
Without seeing the vehicle, it is a tough call. The problem is with the dash lights, you could have an issue with the dimming potentiometer. Possibly a fault in the body control module. You might have it checked for any bcm codes that may relate. There are several possibilities.
Apr 7, 2009 at 2:58 PM
ACEMAN666
I had same problem on my 93 seville turned out my brake light bulb was bad and everything is fine now check your bulbs
Apr 11, 2009 at 1:01 PM
