1989 Cadillac Seville
AFU
  • 1989 CADILLAC SEVILLE
  • 4 CYL
  • 160,000 MILES
The car runs perfect but when let off the gas jerks forward, instead of running forward smoothly. Is the timing the cause of this? If not, what is?
Thursday, November 26th, 2009 AT 10:16 PM
ERNEST CLARK
  • 1,730 POSTS
That sounds like a transmission problem. Is your "Check engine" light on?
Also, with 160K miles, has your trans ever been replaced?
You can drive your vehicle for at least 20 minutes on the streets (stop and go traffic), then pull your transmission's dipstick.
Check to see what color the fluid is and smell it also. If the color is anything other than red, then it's old and needs replacing. If the fluid smells burnt, then that's a good indication your transmission is going bad.
Tuesday, January 19th, 2010 AT 1:29 PM
