1992 Cadillac Brougham Surging Idle
CADILLAC
LOUIS LEE
1992 Cadillac Brougham 5.7 L. milleage 120000KM
tuned up recently: replaced spark plugs, ignition wires, air filter, feul filter, cap & rotor PCV valve.
The alternator replaced as well ( a brand new alternator)
Eversince the tune up, it is difficult to start the engine or takes longer time to start. Once the engine start, it is surging and hesitating.
Your answer is appreciated.
Jul 2, 2007 at 1:12 PM
  • 110,251 POSTS
Hi:
Make sure none of the sensors were left unplugged. If they are all ok, check the IAC and the throttle position sensor.
Nov 17, 2008 at 2:12 PM
Suggested Repair
Confirm no sensors were left unplugged after the tune-up. If connections are good, inspect the idle air control (IAC) valve and the throttle position sensor.
Conversation Summary
The owner of a 1992 Cadillac Brougham 5.7 reports hard starting, surging, and hesitation after a recent tune-up and alternator replacement. The expert advises confirming sensors were not left unplugged, then checking the IAC and throttle position sensor.
