1994 Other Cadillac Models reset codes
1994 CADILLAC
RACINGREGGIE
Air Conditioning problem
1994 Other Cadillac Models V8 Front Wheel Drive Automatic
how do you reset the climate control codes on heads up display on dashboard
Jul 13, 2009 at 12:28 PM
FACTORYJACK
  • 4,159 POSTS
With key on, push off and warmer on the climate panel until all segments illuminate. It will display all codes and return to ECM?. With the fan down button, scroll to ACM, or ACP, and then push fan up to select. From there you can scroll through options like data, inputs/outputs, overrides, codes, and clear codes. When you get the selection to clear codes, push fan up, and you should be done. You can shut key off to exit, or push either auto/econ or the recirc button to exit with key on.
Jul 13, 2009 at 2:54 PM
