1990 Cadillac Fleetwood Code E49 Rough Idle
CLEAN4U
1990 Fleetwood Cadi, Fwd, 4.5, 90,000.
Code E49 is what keeps coming up. New plugs, dist, cap, rotor, pcv, wire fine, egr fine, replaced air charge sensor, replaced 02 sensors,replaced one injector,egr fine, still rough idle.
How can I run a test manually for the air injection pin point the test I need to do? I have the Chit. Man. but can 't find it anywhere. HELP{!!!Thank you :roll:
Sep 22, 2007 at 11:10 AM
BUZZSAW
  • 1,198 POSTS
[quote:4d08f4d072="clean4u"]1990 Fleetwood Cadi, Fwd, 4.5, 90,000.
How can I run a test manually for the air injection pin point the test I need to do? I have the Chit. Man. but can 't find it anywhere. HELP{!!!Thank you :roll:[/quote:4d08f4d072]
I belive the e49 code is that diverter valve on back valve cover the big one, the A.I.R. pump is comming apart and putting debri in valve, make sure what the code is first, I have a 90 or 91 caddie manuel in my tool box
Sep 24, 2007 at 5:53 PM
COCOCHANELS
Who knows where to download XRumer 5.0 Palladium?
Help, please. All recommend this program to effectively advertise on the Internet, this is the best program!
Jun 25, 2009 at 9:25 PM
COCOCHANELS
no any cracks(((
Think, XRumer 5.0 Palladium is really BEST software for promo and for SEO!
Jul 21, 2009 at 1:35 AM
Suggested Repair
Confirm code E49, then inspect the AIR diverter valve on the rear valve cover and the AIR pump. A failing pump can shed debris into the valve and cause the code and rough idle.
Conversation Summary
A 1990 Cadillac Fleetwood owner reports recurring code E49 and a rough idle after replacing plugs, distributor parts, the PCV valve, air charge sensor, oxygen sensors, and one injector. An expert says E49 likely involves the AIR diverter valve and that a disintegrating AIR pump may be sending debris into it, and advises confirming the code first.
