1998 Cadillac El Dorado seal
BLIZFAM09
Transmission problem
1998 Cadillac El Dorado V8 Automatic 180000 miles
What is the simplest way to remove the front pump seal in the tranmision
Feb 4, 2010 at 9:49 AM
FACTORYJACK
  • 4,159 POSTS
You don't necessarily have what is called a front pump seal on a 4T80E, you have a converter hub seal. The only way to replace it is with the transmission removed and converter off. You will either need a seal removal tool, or a flat chisel and hammer will work. Be aware that the case can also crack in this area and cause a leak.
Feb 4, 2010 at 2:45 PM
