The code is probably not telling you the source of the noise, and a noise with the torque converter would not change with vehicle speed. More than likely, you have a fault front hub/bearing on either the right or left side. Does this noise go away when swaying the wheel right or left at speed? That almost confirms a bearing. If you can determine which side, it is not too difficult to replace. Sometimes the difficulty lies in determining right or left, but the part is the same. So if you are incorrect on first try, it is just some additional labor to swap them side to side.
SPONSORED LINKS
Wednesday, September 8th, 2010 AT 11:16 PM
