1985 Cadillac El Dorado High Idle
110,000 MILES • V8 • FWD • AUTOMATIC
IOHOVAH
My Caddie upon start will begin to idle slowly then rise up and up until the engine sounds like its ready to explode. The strange thing that stops this is when I press the brake the engine calms right down to normal operating idle and is fine. it currently has a "service engine soon" light on. sometimes if I haven't started it in a while it will suddenly have a "service now" light on and nothing I do will slow down the idle, but after I pop off the ground on the battery for a little bit and fire it back up it will have no light on and acts just the same as if it had a "service now" light on except when I try to hit the brake to lower the idle, I hear a strange sound under the hood whenever I try to hit the brake. after the next start up it goes back to "service soon" and I'm back to square one. I've check the pcv valve and it is practically brand new. any help is greatly appreciated.
Apr 24, 2008 at 7:14 AM
BUZZSAW
  • 1,198 POSTS
[quote:6a2fbb5cc0="iohovah"]Engine Mechanical problem
1985 Cadillac El Dorado V8 Front Wheel Drive Automatic 110000 miles
My Caddie upon start will begin to idle slowly then rise up and up until the engine sounds like its ready to explode. The strange thing that stops this is when I press the brake the engine calms right down to normal operating idle and is fine. it currently has a "service engine soon" light on. sometimes if I haven't started it in a while it will suddenly have a "service now" light on and nothing I do will slow down the idle, but after I pop off the ground on the battery for a little bit and fire it back up it will have no light on and acts just the same as if it had a "service now" light on except when I try to hit the brake to lower the idle, I hear a strange sound under the hood whenever I try to hit the brake. after the next start up it goes back to "service soon" and I'm back to square one. I've check the pcv valve and it is practically brand new. any help is greatly appreciated.[/quote:6a2fbb5cc0]
sounds like you have a vaccum leak somewhere, when you hit the brakes it uses vaccum up til its full again and then the idle takes off again
look at all the vaccum likes and see if 1 of them is broken, look on the intake, behind the throttle body assy.
Apr 24, 2008 at 10:49 AM
