In the same housing that the air filter is in. To service the air filter, there are two wing nuts. To access the pcm, remove(loosen) the three hex head 8mm bolts around the outer perimeter of the housing.
SPONSORED LINKS
Monday, September 21st, 2009 AT 11:28 PM
