Cadillac Deville overheating
JANGEYER
  • CADILLAC DEVILLE
I just bought a 1992 cadillac deville and it had an overheating problem. The radiator was cracked so I replaced it and then replaced the thermostat, there is circulation, the water pump is working and the thermostat is working, did a test to see if I had a head gasket problem and nothing. The previous owner I had noticed had put alot of stop leak stuff in the cooling system to stop the radiator leak and im out of options except I am going to try to chemically clean and flush the system but after that I dont know what else to do. I have a diagnostic tester hooked up at all times so I can monitor the coolant temp and while driving its been getting up in the 240 range. There are 143,000 miles on the car and its a 4.9l v8 front wheel drive. Any suggestions? Thanks!
Monday, September 24th, 2007 AT 12:35 PM
BUZZSAW
  • 1,198 POSTS
Are you losing any coolant? Check the oil for coolant.
If your not loosing any coolant and the fans are working, sorry but you have a headgasket prob
Tuesday, September 25th, 2007 AT 12:29 AM
