1994 Cadillac DeVille Brake Vibration
Did this start after the brake job or was it present beforehand? 4-wheel disc?
What is likley happening is the rotors are unable to handle the heat from the friction caused by the braking action at additional force. As the heat up, they warp, as they cool the return to flat.
sorry who ever turned your rotors did a bad job, and if you stuck the old pads back on a new rotor turn you probally warped them again. did you do all 4 rotors, push the emergency brake down while driving and see if it is in the rear rotors while holding the release lever
Suggested Repair
Replace the turned rotors rather than relying on another cut; they may be too thin or poorly machined and can heat-warp during higher-speed stops even if they measure flat when cool. Isolate front versus rear by carefully applying the parking brake while moving (hold the release) to see if the vibration is in the rear rotors. Fit quality pads with the new rotors and do not reuse old pads on freshly cut rotors.
Conversation Summary
The owner of a 1994 Cadillac DeVille with a 4.9L engine reports brake vibration at the end of higher-speed stops after new pads and a first rotor turn. The rotors measure flat and thick, the slides are clean, and the front end is tight. Experts say the rotors are likely warping from heat or were poorly machined, and recommend isolating front versus rear and replacing the affected rotors.
