If you have a leak, and the gear itself is not leaking, I don't know why it would need replaced. The alignment may be requested because you show some abnormal tire wear, or it has not been performed for a while. Or the alignment is just there because if you chose to replace the gear, it would need at a minimum a toe set.
SPONSORED LINKS
Saturday, June 19th, 2010 AT 5:08 PM
