2001 Cadillac Deville Check engine light
110,000 MILES • V8 • FWD • AUTOMATIC
9438JSW
We have a 2001 Cadillac DeVille we bought new. Missouri has inspections including emmissions. Our car failed the inspection as it has the "check engine" light on. A local Cadillace dealer tells us we need a new computer and the transmission has to be dropped, a 12 hr job, and have a torque converter or sensor replaced. The total estimate is $3700 plus tax will go over $4,000. Is there a cheaper way to do this. I am told it has nothiing to do actually with emmissions but the State requires if this light is on to have it fixed (turned off) before it can pass the emmissions test. Can you help? We are senior citizens and on a limited income and $4,000 will hurt us greatly.
Aug 18, 2009 at 1:52 PM
FACTORYJACK
  • 4,159 POSTS
Don't know why you need a new computer, the transmission issue is not uncommon, perhaps a code P0741 TCC stuck off. The only thing I can try to suggest is have the codes cleared to turn off the light. It could take some time for this to reset, and that could accomplish your emissions test. The only hitch is, when you clear codes, you also reset the I/M status to unready. If the state your in is concerned with that info, that may cause a fail until the criteria is met for the I/M tests to run and pass, that is what is referred to as an OBD drive cycle.
Aug 18, 2009 at 4:34 PM
