2001 Cadillac Deville
JHIGHJR05
  • 2001 CADILLAC DEVILLE
  • V8
  • FWD
  • 101,789 MILES
I had a diagnostics run on car. They are getting an mass airflow fault. What could that be and what would be a typical cost to fix?
Thursday, February 19th, 2009 AT 2:53 PM
FACTORYJACK
  • 4,159 POSTS
A p0101? What are the symptoms that led to a diagnostic test? I believe there is a calibration upgrade to the pcm to address a p0101. Is that the only code?
Thursday, February 19th, 2009 AT 8:54 PM
JHIGHJR05
I am getting a little stall when taking off. Also it seems to be reving the engine while idling when at a a stop. A smell only when im at a stop.
Friday, February 20th, 2009 AT 10:09 AM
FACTORYJACK
  • 4,159 POSTS
You could possibly have an unmetered air leak. Were there perhaps any lean codes-p0171 or p0174 to accompany the p0101? Was the diagnostic run at a gm dealer, these lean codes could be stored in an area called freeze frame/failure records, and need to be routed out. Your vehicle has the probability that the boot is leaking between the intake and the throttle. It usually leads to higher than normal idle speed(at times), and the lean codes. It can also lead to the maf code. What is the smell, I'm not sure if it relates.
Friday, February 20th, 2009 AT 10:02 PM
