2000 Cadillac Deville oil
96,000 MILES • V8 • FWD • AUTOMATIC
SKINSFAN2
I am loking at a 2000 DHS and it turns out that they only put 5 quarts of oil in at the last oil change, 1000 miles ago. The owner stated that the oil light never came on, but the crankcase holds 7.5 qts. Will this have caused damage?
Feb 10, 2008 at 8:07 AM
SMEDIUM1
  • 5 POSTS
dude 5 quarts are better than 7. thats too much.
Feb 10, 2008 at 9:24 PM
BUZZSAW
  • 1,198 POSTS
[quote:ac3ca206d4="skinsfan2"]Engine problem
2000 Cadillac Deville V8 Front Wheel Drive Automatic 96000 miles
I am loking at a 2000 DHS and it turns out that they only put 5 quarts of oil in at the last oil change, 1000 miles ago. The owner stated that the oil light never came on, but the crankcase holds 7.5 qts. Will this have caused damage?[/quote:ac3ca206d4]
it actually holds 8, .5 qt for the oil filter, no it wont cause damage, oil level lite should have been on at 3 qts down
Feb 11, 2008 at 2:56 AM
ED ARMES
  • 129 POSTS
You title as an engine problem. Was that a statement or a question? Do you have an engine problem? If not then the answer to your question would be that it wasn't hurt. This is depending on whether the driver hot rods around or is a gentle giant. In any case, the oil level sensor system must be repaired if it didn't read low. Oil capacity is 7.5 qts. assuming all is well with dipstick flex in the pan. 8 quarts can get you into trouble as you are getting close to thrashing and aerating the oil with the crank counter weights.
Mar 1, 2008 at 1:00 PM
BUZZSAW
  • 1,198 POSTS
[quote:0239e658e2="Ed Armes"]You title as an engine problem. Was that a statement or a question? Do you have an engine problem? If not then the answer to your question would be that it wasn't hurt. This is depending on whether the driver hot rods around or is a gentle giant. In any case, the oil level sensor system must be repaired if it didn't read low. Oil capacity is 7.5 qts. assuming all is well with dipstick flex in the pan. 8 quarts can get you into trouble as you are getting close to thrashing and aerating the oil with the crank counter weights.[/quote:0239e658e2]
dude you dont know what your talking about it holds 8 qts of oil, its a caddy, go back to your cheverolet
Mar 5, 2008 at 12:47 AM
ED ARMES
  • 129 POSTS
We do move from job to job alot.
Mar 6, 2008 at 10:43 AM
