1999 cadilac devile code p0340 ipc b1910 northstar
1999 CADILLAC DEVILLE
TORAPRT
car has 120k on it it came in and pcm was coverd in coolnt the cam sensor wire was patched the oil sending unit wire was burnt so was the crank wire causing a no start
this is that ive done rewired cam sensor from conector to icm , replaced icm modual , replaced pcm, rewired crack sensor a and b from sensor to icm rewired signal wires from pcm to icm all 6 wires replaced cam and crank sensor but the code p0340 is comes back im thinkinging the cam sprocket might be worn or the sensors too short this was dummed into my lap so im a liitle conserned the engine still runs ruff but it does run now
Oct 1, 2007 at 2:32 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Are you clearing these codes with a handheld scanner or using the on-board diagnostics?
Oct 2, 2007 at 3:35 PM
