1997 Cadillac Deville Engine Overheating
1997 CADILLAC DEVILLE
89,000 MILES • V8 • 2WD • AUTOMATIC
DFJR1973
I have a 97 cadillac deville and the engine just ran hot. I pulled to the side of the road and had the car towed home. I changed the water pump, the thermostat, the pulley to the water pump and the I thought that would fix the problem. I started the car after repairing all of that and the car still ran hot. I checked the fan and it wasn't working. I checked the fuse box and the fuse was blown. I changed the fuse to the fan and it immediately was blown as well. What do I do next and why would this happen twice?
Mar 24, 2008 at 12:22 PM
BUZZSAW
  • 1,198 POSTS
[quote:93dbe0b4b1="dfjr1973"]Engine Cooling problem
1997 Cadillac Deville V8 Two Wheel Drive Automatic 89000 miles
I have a 97 cadillac deville and the engine just ran hot. I pulled to the side of the road and had the car towed home. I changed the water pump, the thermostat, the pulley to the water pump and the I thought that would fix the problem. I started the car after repairing all of that and the car still ran hot. I checked the fan and it wasn't working. I checked the fuse box and the fuse was blown. I changed the fuse to the fan and it immediately was blown as well. What do I do next and why would this happen twice?[/quote:93dbe0b4b1]
you have a short to ground or a bad fan, you have 2 fans and 1 of them should come on when you turn the AC on
Mar 25, 2008 at 3:45 AM
