1996 Cadillac Deville oil in antifreeze
1996 CADILLAC DEVILLE
130,000 MILES • V8 • AWD • AUTOMATIC
BRENTD1
i accidentally poured a lil bit of oil into my antifreeze overfill, will this cause any mechanical problems?
Apr 23, 2010 at 8:37 AM
FACTORYJACK
  • CAR REPAIR CONTRIBUTOR
  • 4,159 POSTS
Should not cause any mechanical problems. Worst case is that it softens the rubber hoses. If it was a small amount, had you known it before running, and tried to get it out? It will stay in the highest point in the system, which is usually the reservoir.
Apr 27, 2010 at 12:03 AM
