1995 Cadillac Deville Rear suspension air ride
1995 CADILLAC DEVILLE
96,000 MILES • V8 • 2WD • AUTOMATIC
GQUICK@CLEMSON.EDU
Air Ride Suspension has rear of car extended upward maximum amount which it stays in. No check suspension light is showing on dash. Can this condition be elimated by turning off Air Ride systen and how would this be done. What is the most likely problem causing this condition?
May 23, 2010 at 1:36 PM
RYAN7010
if you were to shut down the air ride suspension, being as the shocks are only meant as a support, you will soon after have no suspension. take it to a mechanic or leaving it would be your best option.
Jun 3, 2010 at 11:34 PM
