1995 Cadillac Deville car stalling and boging down and not
TIM.HOTTENSTEIN
  • 1995 CADILLAC DEVILLE
Engine Performance problem
1995 Cadillac Deville V8 Two Wheel Drive Automatic
i have replaced the fuel filter and the agr vavle and it still stalling and bogging down
Friday, May 28th, 2010 AT 7:13 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Friday, May 28th, 2010 AT 7:22 PM
