1994 Cadillac Deville How to bleed brake line
1994 CADILLAC DEVILLE
120,000 MILES • V8 • 2WD • AUTOMATIC
TORRENCE
I have just replaced the rotors and pads on the front end but my brakes are still not operating correctly. The brake peddle still goes to the floor. I suspect that I have air in the line but I dont know how to go about bleeding the line. Can you tell me what to look for?
Dec 19, 2007 at 9:31 AM
MERLIN2021
  • 17,250 POSTS
Take the cap off the master, any fluid in it> if not fill it then watch for a leak...is the tires wet on the inside on any wheel? And last, did you pump the pedal to position the caliper pistons?
Dec 19, 2007 at 9:47 AM
TORRENCE
I have done everything you suggested without any success. I dont believe there is a leak the brake fluid is at the same level. I have pumped the peddle it feels like there is just a big rush of air. Is there a valve I can open to let the air out and if so what does it look like? thanks for any and all help.
Dec 19, 2007 at 10:17 AM
MERLIN2021
  • 17,250 POSTS
If you did not change any hydraulics, and the pedal goes to the floor, You probably need a new master cylinder...That is if there are no leaks! The other quistion is what color is your fluid? remove some, put it in a cup, add water, should turn milky, with NO oil bubbles floating on top, I assume only BRAKE fluid was used? I have seen people put tranny fluid in thier brake systems...NOT GOOD!
Dec 20, 2007 at 12:27 AM
