1991 Cadillac Deville
1991 CADILLAC DEVILLE
BILLYBROOKS
Electrical problem
1991 Cadillac Deville V8 Front Wheel Drive Automatic
heat and a/c switch wont blow fan
Sep 7, 2010 at 10:14 AM
FACTORYJACK
  • 4,159 POSTS
Check and see if there is power and ground at the blower motor. If there is, the blower is at fault. If thee is not, check that there is power and ground at the programmer, in the center of the HVAC case(underhood/center of firewall). Another possibility is the A/C programmer under the rh side of dash.
Sep 8, 2010 at 4:03 PM
