My center light works, but the lights do nort work onthe left or right any ideas?
Monday, March 23rd, 2009 AT 10:32 AM
MECHANIC
The high mount light works there's a problem with the joint connector where all the brake circuit meets at. It is not a ground problem. Check for power at the bulb socket with the white wire-do you have it? If not your right back to the joint connector
SPONSORED LINKS
Monday, March 23rd, 2009 AT 10:54 AM
MARKSCTS
MEMBER
Is it a part that will need replaced or simply a cleaning of the connection?
Monday, March 23rd, 2009 AT 12:19 PM
MECHANIC
Do a continuity test from the bulb socket to the joint connector
