2003 Cadillac CTS
2003 CADILLAC CTS
KWHITE1986
2003 Cadillac CTS Two Wheel Drive Automatic 100000 miles
I own a 2003 Cadillac CTS and I'm getting Diagnostic Error Codes:
1. EBC: C1225
2. ECM: P0318
What do these codes mean and what do I need to do/ what parts do I need to fix it?
Also, I checked the codes because the ABS and Traction Control lights came on on my dash.
Thanks
Jul 2, 2010 at 9:02 AM
FACTORYJACK
  • CERTIFIED EXPERT
  • 4,159 POSTS
C1225 is a wheel speed sensor code, the unfortunate part is the code chart does not break them down to respective wheels, you will see what I mean as I attach it. The P0318 is rough rouad detected, and may be related to the wheel speed sensor fault. Since you are experiencing ABS fault, address it first. A scan tool would show which wheel C1225 relates to, but the chart does not. I have ran into this before.
Here is the chart.
DTC C1221-C1235
Circuit Description
As the wheel spins, the wheel speed sensor produces an AC signal. The electronic brake control module (EBCM) uses the frequency of the AC signal to calculate the wheel speed.
Conditions for Running the DTC
C1221 through C1228
• DTCs C1232 through C1235 are not set.
• The brake pedal is not pressed.
• The ABS is not active.
C1232 through C1235
The ignition is ON.
Conditions for Setting the DTC
C1221 through C1224
All of the following conditions exists for 2.5 seconds:
• The suspect wheel speed equals zero.
• The other wheel speeds are greater than 8 km/h (5 mph).
• The other wheel speeds are within 11 km/h (7 mph) of each other.
C1225 through C1228
The EBCM detects a rapid variation in the wheel speed. The wheel speed changes by 16 km/h (10 mph) or more in 0.01 second. The change must occur 3 times with no more than 0.2 seconds between occurrences.
C1232 through C1235
One of the following conditions exists for 0.02 seconds:
• A short to voltage - the wheel speed sensor signal circuit and wheel speed sensor return circuit voltages are both greater than 4.25 volts.
• A short to ground - the wheel speed sensor signal circuit and wheel speed sensor return circuit voltages are both less than 0.75 volts.
• An open - the wheel speed sensor signal circuit voltage is greater than 4.25 volts and wheel speed sensor return circuit voltage is less than 0.75 volts.
Action Taken When the DTC Sets
If equipped, the following actions occur:
• The EBCM disables the ABS/EDC/TCS/VSES for the duration of the ignition cycle.
• The DRP does not function optimally.
• The ABS indicator turns ON.
• The Traction Off indicator turns ON.
• The DIC displays the Service Stability System message.
Conditions for Clearing the DTC
• The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
• The electronic brake control module (EBCM) automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
C1221 through C1224
Under the following conditions, 2 Wheel Speed Sensor Input is 0 DTCs are set:
• The 2 suspect wheel speeds equal zero for 20 seconds.
• The other wheel speeds are greater than 16 km/h (10 mph).
Diagnose each wheel speed sensor individually.
C1225 through C1228
A possible cause of this DTC is electrical noise on the wheel speed sensor harness wiring. Electrical noise could result from the wheel speed sensor wires being routed to close to high energy ignition system components, such as spark plug wires.
C1232 through C1235
If the customer comments that the ABS indicator is ON only during moist environmental conditions: rain, snow, vehicle wash, etc., inspect the wheel speed sensor wiring for signs of water intrusion. If the DTC is not current, clear all DTCs and simulate the effects of water intrusion by using the following procedure:
Spray the suspected area with a 5 percent saltwater solution. To create a 5 percent saltwater solution, add 2 teaspoons of salt to 8 fl oz of water (10 g of salt to 200 ml of water).
Test drive the vehicle over various road surfaces: bumps, turns, etc., above 40 km/h (25 mph) for at least 30 seconds.
If the DTC returns, replace the suspected wheel speed sensor or repair the wheel speed sensor wiring.
Rinse the area thoroughly when completed.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Measures the resistance of the wheel speed sensor in order to determine if the sensor has a valid resistance value.
Ensures that the wheel speed sensor is generating a valid AC voltage output.
Step
Action
Value(s)
Schematic Reference: Antilock Brake System Schematics
Connector End View Reference: Antilock Brake System Connector End Views
1
Did you perform the ABS Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - ABS
2
Install a scan tool.
Turn ON the ignition.
Set up the scan tool snap shot feature to trigger for this DTC.
Drive the vehicle at a speed greater than the specified value.
Does the scan tool indicate that this wheel speed DTC set?
8 km/h (5 mph)
Go to Step 3
Go to Testing for Intermittent Conditions and Poor Connectionsin Wiring Systems
3
Raise and support the vehicle.
Disconnect the wheel speed sensor connector.
Measure the resistance across the wheel speed sensor.
Does the resistance measure within the specified range?
850-1350 Ω
Go to Step 4
Go to Step 8
4
Spin the wheel.
Measure the AC voltage across the wheel speed sensor.
Does the AC voltage measure greater than the specified value?
100 mV
Go to Step 5
Go to Step 8
5
Inspect for poor connections at the harness connector of the wheel speed sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 10
Go to Step 6
6
Disconnect the EBCM harness connector.
Install the J 39700 universal pinout box using the J 39700-300 cable adapter to the EBCM harness connector only.
Test the wheel speed sensor circuits for the following:
• An open
• A short to ground
• Shorted together
Refer to Circuit Testing and Wiring Repairsin Wiring Systems.
Go to Step 10
Go to Step 7
7
Inspect for poor connections at the harness connector for the EBCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 10
Go to Step 9
8
Replace the wheel speed sensor. Refer to Front Wheel Bearing and Hub Replacementin Front Suspension or Rear Wheel Bearing and Hub Replacement in Rear Suspension.
Did you complete the repair?
Go to Step 10
9
Replace the EBCM. Refer to Electronic Brake Control Module Replacement.
Go to Step 10
10
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Jul 2, 2010 at 9:59 PM
