1995 Cadillac Concours
DUNHAM
  • 1995 CADILLAC DEVILLE CONCOURS
Brakes problem
1995 Cadillac Concours V8 Front Wheel Drive Automatic
how to change the rear brake pads on a 95 cadillac concourse
Saturday, October 4th, 2008 AT 4:15 PM
  • 109,885 POSTS
Hi:
The rear disc brakes are the same as any disc system. Just unbolt the caliper, remove it, depress the piston and remove the old pads. Reverse the order to install. NOTE: I recommend when depressing the piston to allow the excess brake fluid to exit through the bleeder. Loosten the bleeder, depress the piston, shut the bleeder before releasing pressure or allowing air to enter the system. If you choose not to do this, make sure the master cylender is uncapped.
Tuesday, November 18th, 2008 AT 8:13 AM
