1994 Cadillac Concours wipers dont shut off
13,000 MILES • V8 • FWD • AUTOMATIC
FLYINGBSTODD
I have a 94 cadillac concourse with 4.6 northstar, The wipers continue to run if started and won't shut off by the switch unless the drivers door is open, or you shut off the key and restart the motor. Also the wipers only operate at one speed. Is this the wiper switch defective or something else? Where is the fuse located to disable the airbags if I have to replace the switch ?
Sep 18, 2008 at 8:26 AM
  • 110,248 POSTS
Hi:
Yes, it sounds like the switch is bad. Regardless of removing the fuse for the air bag, it could still deploy. I recommend having someone who is trained to remove it.
Nov 18, 2008 at 12:24 AM
