1997 Cadillac Catera the engine
99,000 MILES • 6 CYL • FWD • AUTOMATIC
SEAN MURPHY
my cadillac catera has a big problem, it's not running. i ran it till it had no fuel what so ever. now, when i try to run it, it doesn't run. it cranks over and i put fuel in it, but it still doesn't run... any suggestion?
Oct 28, 2008 at 2:20 PM
  • 110,248 POSTS
Hi:
You need to first check the fuel filter to make sure nothing has clogged it. If it's ok, you need to check if the fuel pump is working. Can you hear it come on for a few seconds when you first turn the key on?
Nov 17, 2008 at 2:37 PM
