1997 Cadillac Catera oil change
BONESBOWLING
so...im not a mechanic, but i know how to change oil. My friend recently picked up a cadillac catera and i went to change to oil for him. i was under the car finding the pan so i could drain it, and it appears that i need a star bit to do this. is that the correct piece to drain from? also, i was unable to locate the oil filter, so i was wondering where that is as well.
thanks.
Sep 16, 2008 at 2:42 AM
SUSMAN28888
  • 62 POSTS
Hey there
Yes that star head is correct, No idea why GM would do that on just that car but ya you need a star head be careful not to strip it when removing it. The oil filter is all the way in a silver cainster housing with another star head type head and you need that and a really long wrench a 20 mil if I remmeber correctly and its a tight space you unscrew the cap off the housing and the filter is inside of that, quite a pan for a simple oil change but thats just GM for you...
Sep 27, 2008 at 4:41 AM
