1997 Cadillac Catera fuel system
1997 CADILLAC CATERA
151,000 MILES • 6 CYL • 2WD • AUTOMATIC
REBELHEL
my car acts like its running out of gas. have changed fuel filter, battery and gasoline. Put battery in and it will crank and run, then it cuts off, like it ran out of gas and won't crank back. after a while when battery is reconnected it will do the same thing. Some times it will run and crank a few times before seemingly running out of gas. and yes it has gas in the tank!
Feb 11, 2009 at 11:12 PM
  • 110,244 POSTS
Hi:
I recommend checking the fuel pump pressure. Msny parts stores will lend or rent the gauge. Check out this video on the "How to" aspect of the test.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find.
Feb 16, 2009 at 11:31 AM
