1991 Cadillac Brougham Rough Idle and Stalling
190,000 MILES • V8 • 2WD • AUTOMATIC
JGROFF05
  • 14 POSTS
My car is a 1991 cadillac brougham d elegance v8 305 5.0L. My probelm is this. I will drive on the highway and it will drive fine. Here is the kicker if I go above speeds of 58 what happens is when I come to slow down to a stop my car will start idling real rough and will almost stall out. My probelm is I cannot find what is causing this. I got no check engine light and I cannot find a solution. I have checked every vacuum line and have no leaks. I have replaced the EGR valve, the TPS sensor, the catalytic converter, the IAC motor and still cannot find the problem. I have prot injection and the jets are spraying fine into each chamber of the throttle body and there is no problem with fuel. I am stumped and cannot figure this out. This has been going on for months and I would like to be able to drive my car at high speeds again and not worry about it stalling out. Please help me if you can I am in need of it.
Dec 7, 2009 at 9:53 AM
BUDDYCRAIGG
  • 2,262 POSTS
That really sounds like a lock-up torque converter staying locked up.
Dec 7, 2009 at 5:23 PM
JGROFF05
  • 14 POSTS
Before I go into the tranny and try that I forgot to mention this to you. Here is another wrench into the mix. I would put fuel injector cleaner into my tank and I could drive freely at any speed and I would not experience any of the problems but when I run gas without the cleaner in it that is when this rough idle problem occurs problem occurs. I use STP fuel injector cleaner and that allows my car to run at high speeds without messing up when I come to a stop.
Dec 8, 2009 at 12:22 AM
BUDDYCRAIGG
  • 2,262 POSTS
I've been thinking about your new info all day and my hurd hets, I mean my head hurts.
It's not like we are in a back to the future movie where "when this baby hits 58 MPH, watch out..."
These are the two things that I can think of before my head explodes.
1, the EGR valve is opening up and not closing fast enough. (you can disprove this by running with your EGR unplugged for a few days)
2, you have high compression from carbon build up and are getting detonation after a lean cruise on the highway. (you can disprove this by running the fuel tank almost empty and then putting in a 1/4 tank of premium octane)
Dec 8, 2009 at 3:50 PM
