1989 Cadillac Brougham
JAMES456456456
  • 1989 CADILLAC FLEETWOOD BROUGHAM
Engine Mechanical problem
1989 Cadillac Brougham V8 Two Wheel Drive Automatic
i need to know the firing order and where number 1 is
Tuesday, August 4th, 2009 AT 4:41 PM
FACTORYJACK
  • 4,159 POSTS
Order is 1-8-4-3-6-5-7-2. #1 is at the front of the left(drivers side) of cylinders. The best way to find #1 on the cap is with the plug out, crank until compression develops, line up the timing mark on the balancer with 0 on the scale, and pull the cap to see where it points. This is the sure shot way. If someone has had the distributor out and it is out of reference, The book location may not be correct.
Tuesday, August 4th, 2009 AT 9:44 PM
