1987 Cadillac Brougham
KTC123
  • 1987 CADILLAC FLEETWOOD BROUGHAM
Shakes or Wobbles problem
1987 Cadillac Brougham V8 Two Wheel Drive Automatic
When I start driving my car there is a fluttering sound coming from underneath of the car. After a while when I try to stop the car acts like all the gears wont downshift until the car slows down and then the car wobbles and shakes when I slow it down. All the gears seem to downshift at the same time. The fluttering gets louder when I accelerate and makes the car shake unless I give it extra gas. The car never cuts off but shakes like it will until the gears shift down to first. I heard it could be the t/v cable but I dont know. It seems like once the tranny gets hot then the downshifting and upshifting gets crazy. Please help cause the car runs fine except this problem. Thanks.
Monday, March 1st, 2010 AT 1:31 PM
2CARPRO JACK
  • 11,533 POSTS
If the trans upshifts like it is supposed to it probably isn the TV cable. Since these problems change with temperature, it is most likely a problem inside the trans. Try a service first (filter kit) to see if that changes/helps anything.
Wednesday, March 3rd, 2010 AT 7:48 AM
