1978 Cadillac Brougham Carburetor
132,000 MILES • V8 • 2WD • AUTOMATIC
MACGYVER5149
I'm running rich, and black smoke. What do I adjust?
Nov 1, 2008 at 7:22 AM
  • 110,246 POSTS
First, make sure the choke isn't sticking closed. If it's ok, there is an air fuel mixture on the front of the carb. Turn it in the entire way, and out 1.5 turns. Start there. See if it improves the problem. You will most likely need to fine tune it, but that is the starting point.
Nov 17, 2008 at 12:24 PM
