cabin pollen Filter location and replacement
2005 NISSAN ALMERA
74,000 MILES
NICHOLASGHILL
The car is in fact an Almera Tino which is very different from an Almera. Exactly where is the filter located t and how do you change it please?
Do not know whay else I can say as i have tried to explain my problem simply.
I have taken the glove box off but I can't see the old filter!
Jun 4, 2013 at 4:33 AM
KHLOW2008
  • 41,814 POSTS
Sorry we do not have any information for your vehicle and do not know if it is equipped with a cabin filter.
Since you hace taken off the glove box, check for a rectangular plastic slot. If there is one, the filter should be behind it. Some manufacturers requires a certain portion of the cover to be cut to remove and replace the filter.
Post some pictures if you can and maybe we can tell you if there is a filter there.
Jun 5, 2013 at 4:40 AM
