cabin heater not producing hot air
81,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
DENSAILS
My heater is not working properly in my car. I have some heat but its very little. I can have the heat turn on high and can hear it but when I out my hands next to the vents, I can feel very little or no air at all. Once I have driven it for 30mins, its a little warmer but never full air coming out of the vents. It always sounds like the window defroster is on and it receives more power and heat but never the full capacity.
Jan 1, 2014 at 2:39 AM
  • 110,246 POSTS
Is the problem that the heat is not hot or is it there is little air flow from the vents? Is it coming out the defroster with full power?
Jan 1, 2014 at 10:08 AM
DENSAILS
Air comes out of the foot wells but is barely warm never hot. The air from any of the vents and defroster is not "hot". Engine coolant is full and no leaks. Thanks.
Jan 2, 2014 at 6:22 AM
  • 110,246 POSTS
Okay, that leaves only a couple issues that can cause this. First, I need you to start the engine and allow it to warm up to normal operating temp. (You can do this after a trip too). With the heater on high, I need you to feel both heater core hoses. Both should be very hot to the touch. If only one is hot and the other warm, chances are the heater core is partially plugged. If both are hot, then I suspect the blend air door is not opening properly and allowing the heat to enter the vehicle.
Check that and let me know what you find.
Jan 2, 2014 at 6:46 AM
DENSAILS
Heater core hoses are both hot. How can I access the mixing doors. Is the problem likely an open vacuum line or the dash controls or a fuse somewhere?
Jan 7, 2014 at 11:49 AM
  • 110,246 POSTS
It could be a broken line or bad actuator. The door is located near the heater core in the heater core box. Not easy to get to.
Jan 7, 2014 at 11:19 PM
