Buzzing sound
250,000 MILES • 4 CYL • AUTOMATIC
SHAUNACEE CONDO
There is a faint buzzing sound coming from the dashboard area in my car. The power steering fluid was low, so I topped it off with the recommended fluid. That did not solve the problem. I have not changed the fluid. So now I am stuck. All the other fluids are newly changed and full. It is only audible when the car is moving. The steering wheel has also become a lot easier to move. It almost feels lose. But it could be that I have been used to a tougher steering wheel because of the power steering fluid being low. I have read that it could be transmission, but I was just at my mechanic and he said it was fine. I also read that it could be wheel bearing, or a failing power steering pump. I do know that my tires and wheel are misaligned, could this be creating the problem? Could it be that I need to flush out my power steering fluid? Is it safe to drive?
Sep 28, 2017 at 1:02 PM
  • 55,711 POSTS
As with all noise problems I cannot not hear it so I would just be guessing unless you can make a short video of the noise you are taking about and upload it this thread.
Cheers, Ken
Sep 29, 2017 at 4:01 AM
