How to replace bulb on shift indicator on the car listed above?
Jan 8, 2017 at 6:39 PM
STEVE W.
✓Experienced Mechanic
Very gently pry up on the console around the rear edge where the seam is, it is clipped in place with four clips. The trim will tip up in the back and pull out from under the dash trim. The shifter will be exposed and you remove and replace the bulb.
