Building up pressure and overheating
195,000 MILES • V6 • 2WD • AUTOMATIC
DEFD0PE
I have the car listed above that keeps overheating. I've already put in a new radiator and check the thermostat. Also it keeps building up a lot of pressure like a lot of pressure to where the radiator hoses are swinging from the bubbling. I did bleed the air out of the line. I just don't understand what's going on. any help would be hugely appreciate it.
Aug 2, 2020 at 12:09 PM
DEFD0PE
Update: asked the question while sitting on the side of the road waiting for the car to cool down. when I just checked it the radiator hose was flat because of all the suction. so definitely thinking wrong radiator cap but that still doesn't solve my problem because I just put that radiator cap on there because the last one wasn't working. but it wasn't doing that either it just was filling the overflow reservoir until it was spraying out. please help.
Aug 2, 2020 at 12:15 PM
STEVE W.
  • 15,411 POSTS
The only place pressure like that would be from is a bad head gasket. In normal operation the system runs under about 12-15 psi. and shouldn't overheat. I would start by doing a pressure test and a combustion gas test.
You can usually get the test equipment at many parts stores as loaner or rental tools.
From there you would need to determine which way to proceed.
Aug 2, 2020 at 1:06 PM
DEFD0PE
I thought head gasket too, but didn't see any coolant in the oil. I will do that that though. thank you
Aug 2, 2020 at 3:20 PM
STEVE W.
  • 15,411 POSTS
It depends on where it fails as to whether it goes into the oil. it's possible as well that it's a crack in the head or block. They would all show up the same way. Testing gives you a place to start.
Aug 2, 2020 at 6:54 PM
