Speedometer and tachometer quit working and fuel gauge stuck in middle position
1996 BUICK SKYLARK
70,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
THOMAS HALTON
Replaced the VSS sensor thinking it would fix the problem. however, it is still the same and having problem shifting also. I was told a transmission pan gasket and filter change. Could help the issue.How would that do anything for gauges?There were no blown fuses I could see. ever had these issues fellow humans? Could it be the connector for VSS? Also my scan wont show codes it has kinda got me. Please help me. Thanks all
Oct 26, 2019 at 8:07 AM
  • 55,423 POSTS
I have seen the clusters go bad causing this problem. here is a video of the repair being done on a similar car. Also you may try to unplug the cluster and then plug it back in again it could have a bad connection.
https://youtu.be/_HEC44xENxw
Please run down this guide and report back. Be sure to give your VIN and mileage to the rebuilder so it can be programmed in.
Oct 28, 2019 at 6:02 AM
