1995 Skylark sputters at idle and drive.
JOHN1974
  • 1995 BUICK SKYLARK
I have a 4cylinder 1995 skylark which started to sputter recently. I thought it was the spark plugs so I replaced those and it still did it. It was only once and awhile and today on my way home from work it starter doing it 100% of the time. It sputters like a plug is bad but we know its not it. I cant get the car over 30mph.
any ideas? No check engine lights are on.
Monday, July 16th, 2007 AT 9:30 PM
KREFLO
I am having the same problem with my wifes car, and was wondering if you found out what the problem was? Thanks in advance, Jason.
Friday, September 7th, 2007 AT 3:55 PM
RAGMAN
Now I may be wrong but I was told that when a car wont go over a certain MPH then the problem is either a vacuum leak or a map sensor.
Mine was sputtering just like that and there was a small vacuum hose right on the front of the motor that was falling off and cracking. Replaced that, it was like night and day. But now I had the problem again and the hose is fine. I couldnt get it to go over 25mph. I was told it may be the map sensor. Now I just need to find out where the map sensor is on the car-heard its not too difficult to replce, once I find it.
Thursday, October 4th, 2007 AT 7:21 AM
BERNESTINE
[quote="john1974"]I have a 4cylinder 1995 skylark which started to sputter recently. I thought it was the spark plugs so I replaced those and it still did it. It was only once and awhile and today on my way home from work it starter doing it 100% of the time. It sputters like a plug is bad but we know its not it. I cant get the car over 30mph.
Check engine comes on but goes out
Thursday, November 29th, 2007 AT 4:53 PM
JOHN1974
  • 11 POSTS
Just to let everyone know I solved the problem. It as the white tower that runs to the spark plugs.
Monday, June 29th, 2009 AT 1:25 PM
