How to change a heater core yourself
1993 BUICK SKYLARK
JOANNE HERRON
Heater problem 6 cyl Front Wheel Drive Automatic 199900 miles
I need instructions on how to change a heater core in this type of car. Thank you.
Feb 11, 2009 at 4:23 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
You must start by disconnecting the battery to avoid electrical problems when doing the job. Here is a guide that will give you an idea of what you are in for.
https://www.2carpros.com/articles/replace-heater-core
You will need to vacuum down and recharge the air conditioner system here is a guide for that as well.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Check out the diagrams (Below)
Cheers, Ken
Dec 5, 2017 at 3:30 PM
FIREFLY77
heater core has blown several times
the shop says that voltage is going through coolant between 3 and 6 volts
causing added pressure and blowing heater core
what would be a fix for this
The shop has replaced the heater core several times
does not work on real old vehicles that much
they did find a bulletin that original cores was brass and could hold additional pressure
Dec 5, 2017 at 3:30 PM (Merged)
  • CERTIFIED EXPERT
  • 110,175 POSTS
First, I'm not sure why there is an electrical current in the coolant. There really isn't anything that should cause that. Also, it wouldn't cause additional pressure. The lid on the radiator is set to release pressure when it reaches a certain point, so excessive pressure shouldn't be an issue. However, if the lid is bad, it could cause additional pressure to build. Has the radiator cap been checked or replaced?
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
That is call "electrolysis" and if happens when there is a ground problem somewhere and the current is finding it's way back the the battery ground by going through the cooling system. The root cause is usually a bad or missing body ground somewhere.
FIREFLY77
How can that eltrolysis occur and what kind of short can cause this.
Is this a known problem for older cars.
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
I've already explained that.
BONNIEBUTLER
Heater problem
1992 Buick Skylark 4 cyl Two Wheel Drive Automatic 160000 miles
How do I change the heater core?
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
Does your car have air conditioning?
BONNIEBUTLER
Heater problem
How do I change the heater core in this buick?
BLUELIGHTNIN6
  • CERTIFIED EXPERT
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2685.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_692.jpg
