1993 Buick Roadmaster coo;ant
235,000 MILES • V8 • 2WD • AUTOMATIC
RON THOMAS
can this car run only on warter in the coolant system.
May 4, 2010 at 4:01 AM
VEGASFARMKID
  • 30 POSTS
yes it will run with just water in the system.
But, if you are running in hotter temp than average ( Arizona). anti freeze/ coolant will handle hotter temps, without boiling, than just water.
As with cooler temps ( U.P. Michigan) anti freeze/ coolant can handle much lower temps, without freezing, than just water.
May 4, 2010 at 7:39 AM
