Any suggestions on how I can remove my tail light bulb?
BUICK RIVIERA
FLIGHTY
I have a 1989 Buick Riviera. I'm attempting to replace the tail light bulb, I have the assembly out so I can get to the bulb, but it will not budge. I've tried twisting, pulling...everything I could think of. I also managed to break the bulb in the process. Did I do something wrong. Is there some other way I should have gone about this or does it sound like it's just stuck due to age?
Thank you for any advice or comments.
Sep 20, 2007 at 11:29 AM
CLY
  • CAR REPAIR CONTRIBUTOR
  • 308 POSTS
sounds like you did it correctly but t is just stuck in there. you may have to wind up getting a new socket for that if you can't get it out. You should be able to pick one up at most auto part stores and then just splice it in...
Cly
Sep 21, 2007 at 5:33 AM
